2.5L ('98-'01) 2000 2.5L Auto Pulsing Vibration at All Speeds.
HighMileage93
Bridgeport, IL 62417
Dad's Ranger started acting strange all of a sudden last night. Pulsing vibration at all speeds, downshifting different than before, stopped at light and idle dropped way down and rough, oil pressure guage dropped with needle wag, light turned green and could barely get it to take off. When it finally did take throttle again it was abrupt and spun the tires. Did this the rest of the way home. This morning, started and idle went high and took a good while to come down some but not to normal. Seems like delayed shifts too. WTH? No check engine light and no stored codes.
I moved this to the correct engine forum.
Most times when you have unstable idle it can be related to a vacuum leak. Depending on where it is... other symptoms can also be noted.
I would pop the hood and take a long visual inspection of all vacuum hoses first.
Doesn't mean the HEGO is bad...
Could mean a vacuum leak making the sensor trigger the code.
Rich for a vacuum leak? First thing I'd check is the vacuum line to the fuel pressure regulator if 2000 still has one on the engine.
That went away in '98 I think but there sounds like some type of issue, might be worth checking the fuel pressure...
Running rich would explain some things, could be the MAF reading high airflow which is usually backwards of what happens but it's also backwards of what a bad O2 sensor normally does or even a vacuum leak so I'm not too sure.
