2.5L ('98-'01) 2000 2.5L Auto Pulsing Vibration at All Speeds.
You're not wrong but would still indicate high leakdown on both the middle cylinders... plus if you have all the plugs out at the time it would come out the plug hole.
I don't trust some leakdown testers, I bought one that only pressurizes the cylinders to like 10psi, I don't think that's high enough to test everything... plus you're trusting whatever the gauges say... at work we have ones that just have two gauges so you can do the % yourself or just be lazy and air up to 100psi and see how far off the second gauge reads...
what about compression testing #2 with and without the plug in #3 to possibly show a difference?
Compression probably wouldn't, pressurizing one of the two cylinders locket at TDC and seeing if any air is coming out the other spark plug hole would be a good test for head gasket.
Update: Mechanic swapped a new valve onto the compression tester and now getting 150 psi on all cylinders.
Next question: Anyone here run on just one coil pack? Will the computer throw a fit about it?
It depends on what you mean... if you have everything up to snuff on the exhaust side and don't have good stuff on the intake side you'll be fine... if you decide to run without that coil pack you need to at least ground out the two outputs so the computer doesn't know you're playing games
Okay guys, believe it or not, the truck "fixed" itself. LOL.
No parts replaced, just diagnostic work. Truck started running fine again. Scans show everything in spec. Thinking MAYBE dirt in the #3 injector. IAC valve might be a little weak. Put some fuel injector cleaner in it and just running it at this point. We'll see how it goes.
Thanks for all the input.
Maybe you just had a bad connection from one side of some plug wires. Pulling them off and reconnecting a few times may have gotten a better connection. Either way I hope it stays running good and treats you well.
