carbon_crashed
Hey guys, I am in serious need of some help with my 1990 2.9L Ranger(auto, 2wd). The other day, as I started the engine, I noticed it was running a little rough and I had a CEL. As I pulled out of my driveway, it died. I tried to crank it back up and it would only turn over but not start. Since then, I've tried to retrieve the code the computer is throwing, and I haven't been successful in gaining the code. One other thing about the truck is when the Key is on but the engine is off, the fuel pump continues to run rather than shutting off and several seconds of no ignition. Anyone have any ideas or a way I can pull the CEL code? I've tried the jumper wire on the self-check port and a test light/volt meter. Hopefully someone can help and/or give me some ideas of what the issue may be. Thanks in advance!!
