Reads like there was and is sediment in the rad which was why the drain wasn't working at first.
The brass plug in thermostat plate is the "jiggle valve", it is there to let air out when refilling, the loose plug "jiggles" to keep the hole open so any air can get out, the "jiggle valve should be installed at 12:00 position, where any air might be.
This part is about air not cooling.
Thermostat is located on the upper rad hose, when you start a cold engine the thermostat is closed, so upper hose should not get warm.
When engine has heated coolant up to 180-190degf(5 to 8 minutes) then thermostat will start to open and coolant will flow into upper hose and it will heat up then.
Cold coolant in the rad will then flow out of rad thru lower hose and into water pump.
When the cold coolant reaches the thermostat it will close again.
Then as the new coolant heats up it will open again.
This open and closed cycle repeats until rad coolant is warm.
You need to remove a radiator to flush it.
You can also do a "Flip test" when it is out to see if it is worth while flushing it.
Remove rad
Plug trans cooler openings
Put rad cap on
(Look at the tubes in the rad, turn rad so tubes run up and down)
Stand rad up with tubes running up and down
Turn on garden hose
Put hand over lower rad opening
Fill rad with garden hose using upper opening
Stop filling when full
Remove lower hand
Rad should drain very fast
Tilt rad to get all water out
NOW the test
Flip rad upside down
If ANY water comes out it could only come from blocked tubes
You can not "Flush" out blocked tubes, time for new rad
If rad passes test then lay it flat, hose outlets facing up
Use warm or hot water with CLR or Vinegar mixed in
Fill up rad and let it sit for 20min
Flush it out and repeat as you see fit.
Give it a good flush with water before reinstalling.
Remove rad
Put rad cap on
Turn on garden hose
Remove lower hand
NOW the test
