2.9 & trans swap 2wd to 4wd
tate22
1989 bronco ll
Are there any issues taking engine & trans from a 2wd and placing them in 4wd? both automatic trans, same year truck.
BIIs or Rangers?
If the 2WD vehicle has the dummy transfer case as was used in many if not all 2WD BIIs then it should. I don't know if those dummy transfer cases were used in Rangers at all. Rangers had more drive configurations.
None that I can think of. It should bolt right up. You will have to swap the extension housing on the trans though
