let me know if you decide to go through with it, becuase ive been thinking of using the same kit. and a 4.0 only has like 20 more horsepower then a 2.9 and the stroker kit would put the 2.9 at about 190? and you wouldnt have to deal with working out the bugs of swapping. i think it will be my next upgrade this coming summer.
a stroker 2.9 making 190hp?
PLEASE don't repeat dillusions based on "second hand smoke" from the CRACK pipe that the people selling these things have obviously been smoking.
a a stroked 2.9 turned into 3.5 isn't going to be revvier than
a 2.9 or even a 4.0. (it takes rpm to make power)
And it isn't going to be making more torque than a 4.0.
If you drove a 4.0 truck essentially identical to yours with a 4.0 you'd understand what the more experienced guys have already discovered...
That the inexperienced talk about horsepower, the rest of us talk about torque.
Yeah the 4.0 only makes 20-25 additional horsepower., but it makes an additional 55ft/lb of torque. that's 1/3 more FORCE turning the transmission input shaft.
Not only that the 4.0 is already making 194ft/lb of torque at 1000rpm.
and >200ft/lb all the way to the 4200rpm power peak.
The 4.0 does effortlessly what the 2.9 struggles to do even if you
tickle it right...
Torque is what makes the wheels go round, Horsepower only
determines how fast.
It's simple physics.
BTW, for the price of a $2500 stroker kit I can BUY more than one complete running 4.0 powered rangers.
For the price of the Morena stroker for a 4.0 I could build
a really killer stroker 302 starting with a NEW block.
You wanna be different? Smear your body with feces, stick a peacock feather up your butt and run down the street naked screaming "I'm a peacock ain't I beautiful" while jerking off.
that'll make you "different"
Different ain't "Better".
AD
