2.9 timing indicator
librum
NOVA
Had to pull the distro, and now having trouble. The engine fired, fast idle, when I punched the throttle to drop from fast idle, it died, and now will not start. No spark at plugs.
So I am back checking everything. Either I am slightly off, or fried the Ignition Module.
Problem is that the timing marks are not what are shown in Chilterns/Haynes/Blue Book. There is no ladder/scale.
What I have is this:
The 'bullseye' is on the bottom, slot on the pulley in the middle, and pointer on the top. I seem to recall reading that at one time the ladder was a decal, so obviously long gone, and that the 'bullseye' was to hold a drift in the slot to lock the pulley. Or am I spacing? Is the notch the TDC mark for the pointer?
Any clues before I repull the air intake to recheck the distro.
Hoping it is not a ICM.
The timing marks were on a decal, but they are also scribed into the damper, probably covered under dirt. The slot you showed there probably is TDC.
Anyway, I doubt that's your issue. If you have no spark, well timing won't cause no spark. It will cause spark at the wrong time. Say no spark at any plug doesn't do much to narrow the field since most of the system is on a single line. Probably the TFI. Not sure why that is such a dreaded thing for you, they aren't that expensive or hard to replace. Takes me more time to drive down to the store and wait for the counter goon to look it up than it takes me to put it on.
Yeah they are easy to do...Just don't lose those little screws! That's about the worst of it.
Even if it's not it, it's good to have a spare in the glovebox.
Thanks for the responses. No decal, and I just finished buffing to find no marks. But not a biggie. I will white mark when I find the TDC.
I am just trying to zeroize everything before I find out what the 'off' setting is, or t/s the system...
Next is the old probe in the cylinder again to find TDC, as the distro was disturbed, so can't trust that. Again, it ran, until I touched the gas to get off fast idle, so can not be that far off.
May be back with idiot questions...
Update, the notch is not a timing mark. Per an old FMM I know, they are for orientation when the engine originally built. The decals are available but I could not see paying over 20 dollars as I could not figure a way to get the wheel clean enough for good adhesion.
The decal does orient off the notch, but notch is about 165 degrees after TDC. Using that figure, the engine is running, poorly, but running.
Now I have to find this false code 11, and figure if related.
Thanks again for the responses.
