dirtracer11591
Alright guys, I need some fellow mechanics to bounce ideas around with because I'm running out of them. Im working on a 87 2.9 ranger with ammeter for a buddy of mine. The ignition skips at idle and cuts out so bad under load it doesn't want to rev past 2000 rpm. It COMPLETELY clears up when the voltage regulator is unplugged or when the alternator belt is so loose it basically isn't putting any load on the engine. This is how I received the truck but from my understanding the truck wouldn't start one day, PIP ended up being the culprit. The ignition cutting out started once it started running again. My buddy and the shop he had look at it before me has basically replaced the entire ignition system, some pieces multiple times and even tested with another ECU. With my spark tester inline with the coil wire I can clearly see the ignition cutting out. Before I discovered the alternator behavior I tested the fuel system and verified nothing was amiss there.
The only thing I have done aside from diagnostic is replaced the alternator and internal regulator which didnt help. From there I assumed it was a wiring issue and I'm a little at a loss here as the new alternator didnt have exactly the same plugs so I had to crimp some wires to adapt but that left some unhooked wires and the regulator plug seems pinned differently than the wiring diagrams I have found so far.
His truck has the yellow wire on the A terminal, the green wire on the S terminal, no wire pinned to the I terminal. There doesn't seem to be a wire too hook the new alternators S terminal too off the stator connector. If im not misunderstanding the green key on wire should be on the regulators I terminal, the stator S wire should be looped too the regulators S terminal, rigged that up to test but didn't seem too help. Anyone have any bright ideas?
I appreciate any help, this truck has been down for months and now that I've got my hands on it I see why. I did see a couple threads where people had a similar issue but go figure, the resolution was never posted if it was found.
