ok...i got a fan on it..i made a toyota one work...now...its making alot of pressure in the radiator.....and keeps blowing the coolant into the over flow box...do you think its the head ? it starts blowing steem out the tell pipe i dont know if its bad gas or what!
how hard is it to put new HEAD GASKET on ?
oohhh ...that doen't sound to good. ealier you mentioned some one told you it was a bad head gasket....who mentined that? was there testing invovled?
some checks you can do at home;
With the radiator cap off..start the truck...(cold start)
get so you can see both (if you can), in the radiator and the tailpipe, or check both often. OR get a buddy to help.
In the radiator...watch for bubbles....also go back to the tailpipe put your hand in the exhuast stream for a few seconds...then smell your hand, if it smells sweet like anti freeze...then you have a bad head gasket or head issues.
yes, head gaskets can be installed incorrectly.
it is normal for steam/white exhuast to be present on initail start up...BUT should go away after a few minutes of running...how long the steam/or visiable exhuast stream is present with correctly operating car or truck is directly proportional to how cold it is outside ....the colder it is the longer you see the exhuast.
for example ; for about 32*F you should see some exhuast for only about 2-5 min.
if you have bubbles...have the radiator pressure tested & checked for exhuast gases present in the anitifreeze.
hope that helpes
