Well another vehicle scare, on my way home from work was going down a main road doing 35mph 3rd gear about to go into 4th and just started surging baddly, didnt want to run, with clutch pushed in it didnt want to get above 2000rpm real easily. It finally died, when to make an emergency right turn but due to the ground being wet, didnt quite make the turn, almost ended up air born over a curb, had all 4 tires sqeeling to a stop. Fuel pumps were still working, so waitd a bit she starte up, a cut through a house complex, surged then died, got under my hood, backed out the fuel regulator screw, got her started, ran, then surged real bad for a bit but it stopped, limped her home in 2nd gear with hazard lights on, and right before I got home,got on her and no problems. Ran fine the past two days with screw turned in on my regulator. Think my TPS is going out due to it having fire damage from my truck catching fire way back, or a fuel pump problem, think I have a spare TPS in the garage.
