chayse brooks
- Mar 2, 2015
Is there any performance parts the 2.8 l that are worth getting and if so what's a good combination to build power and retain some mpg
Well it does have some carburetor problems with it having some play and I had to replace a bunch of vacume lines that leaked. Speaking of which is it smart to take off the smog stuff and get it running with out it. I've heard that that takes up some power. The engin is also coated in a film of oil but that's getting cleaned off as soon as it warms up out side
You can do the duraspark conversion and bring that engine to life again. Eliminate the computer harness and all the vacuum lines. Get the distributor and module I got my harness out of a 1984 2.0 ranger for the distributor. If it is a 1983 or 84 it is pretty much plug and play. I only had to splice one wire and had it running. You can use that carb just get some #42 jets and a rebuild kit.
