- May 12, 2025
- California
- 2.5 (4 Cylinder)
- Manual
Alright hopefully someone in here might be able to point me in the right direction.
2000 Ranger 2.5L
190k
Chasing a cylinder 3 misfire. Only throws P0303.
Replaced all these parts in the past 4/5 weeks;
new plugs all around
New plug wires
Two new motor craft coil packs
New air filter
New MAF
New IACV
New TPS
New DPFE sensor
New cam position sensor
New 02 sensors (upstream and downstream)
New gaskets at throttle body, intake manifold, exhaust manifold, valve cover, egr.
New timing belt and tensioner.
New thermostat, housing, and sensors.
New fuel filter
New injector at cylinder 3
compression at all cylinders above 165 psi
Passed leak down test with flying colors (to the point where I’m almost certain this is not the factory head. Put 70psi in the cylinder (multiple) and they didn’t leak AT ALL, could that be indicative of an issue? I know 8-10% leakage is typical)
Valve train looks damn clean (no broken valve springs, sludge, or anything like that)
Put a borescope in cylinder through exhaust ports and can’t seem to see any valves stem seals leaking or valves burnt up.
Vacuum gauge reads 16lbs/vacuum.
Fuel pressure 65psi at the shrader valve on the fuel rail.
Exhaust back pressure test ruled out bad cat.
I feel like I’m so close to fixing this, but I have no clue where else to go with parts or tests. Mind you, I’m about the worst mechanic you’ll ever meet. I’ve heard of the PCM failing on these, but I feel like it would cause other issues too? Not just the consistent P0303. The truck runs pretty rough when cold, then better once it’s warmed up. Will still on the occasion stumble and sometimes die when coming off the pedal into a stop sign/light.
Been trying to monitor live data while driving and idling, but honestly don’t really know what I’m looking at vs what I should be looking for. Could it be something with the egr control purge valves? I’m sensing it’s vacuum/air related because at one point it threw me a P0171 too lean code (only popped up once, cleared and hasn’t come back, but the P0303 did.) Could it be EGR related? I’m banging my head into the wall at this point hahaha.
can anyone maybe point me in a direction that might help me out? PLEASE AND THANK YOU
2000 Ranger 2.5L
190k
New plug wires
New air filter
New MAF
New IACV
New TPS
New DPFE sensor
New fuel filter
