Are you sure they increased the compression in 94? That would make sense with obd2 having a potentially better management of the engine. However what I am proposing is that the 93-94 ranger is limited by fuel not air. Maybe I am wrong, but on steady hills I can feel an increase (however slight) in power by not flooring the pedal. Which to me would indicate that there is a lack of fuel and the a/f ratio is producing a less than ideal explosion.
The Ranger has a cold air intake from the factory. A port and polish job may increase the flow rate of air into the motor at a very high rpm, but that's it, and your computer will compensate with more fuel. Without internal engine mods or forced induction, the volume of air is not going to be substantially increased to a level where you will need higher flowing injectors.
If you think your truck is running lean when the throttle is fully open, you might have a faulty sensor or two, or dirty/bad spraying injectors (bad grounds, corrosion on injector terminals..etc)
Without forced induction and or internal engine mods, putting higher flowing injectors in will do nothing but make your truck run pig rich and like shit.
