2.3 performance
mongo
ok so im in the process of buying a 95 ranger 2wd 5spd
its $500
its needs a clutch and heater core
a few questions first how hard it a heater on one of these
and does anyone know where i can get a lightweight flywheel in trying to find one
but the plans are
cai thrush welded to duels out the back
jet chip bigger injecters hurst shifter shave the head port and polish
a 2in drop and a few miss. parts on the out side what do you think
well and a light weight drive shaft and full synthetis all round
hey thanks man ive been looking all over but i didnt really find anything thats for your help
can anyone back this up at all
they have the same bolt paddern but the holes are diffrent is the escort flywheel ballanced
If you want a power gain out of a 2.3, put turbo on it. Porting and polishing the heads might help. A lighter fly wheel will help too. As for the bolt paterns, no clue, might be a case of trial and error.
If you were adding a cold air intake, the truck came with that from the factory, ford built it right leave it alone. If you were adding headers, not much of a gain or non at all.
well.. i have a cold air kit for it and i really did get much out of it except to say i have one it was a off day with random parts but i didnt loose anything and in upping the injector size and putting in a cam so i will need a little more air but it mostly just so when i pop my hood people who like cars and know nothing about them can act like they do when they see something shiney
for the heater, ive been reading about it cause i need to fix mine. you got to take apart the dash bord. and for a 95 up till at lease 97 it means takeing the steering wheel, parking brake, hood release, fuse box, and radio off(maybe more). but just need to take your time and lay out all the parts you take out in order, and you should be good, but get a haynes repair manual for you truck, can get one at almost any auto store. should have one anyway. also it might be the Blend Door, read this http://www.therangerstation.com/Magazine/Summer2009/blend-door.htm it will give you the 411 on it. have fun:icon_thumby:
yeah well i got to buy it first
and ill keep yall up dated i might try to add it to the tech books
but im really not not not looking fowored to it and winter is well on its way
and guy i like to take time to say thanks and sorry for my spelling issues d@mn lisdexia
Mongo,the truck that we are racing now,a 98 2.5,has a escort flywheel in it.The last two trucks we build had escort flywheels in them.We run that and 78 Granada clutch and pressure plate as they are lighter.This is a common thing to do when you race in a stock class and have to use stock componets.A couple guys are running a Tilton setup but haven't got caught with it yet.You can go to www.4m.net and go to the mini stock page to find out more.If you want to see some pics of our truck,go to www.adirondackspeedway.com and look at the 22 truck
its $500
but the plans are
The heater core is about a 10-15 minute job.....very, very, very simple.
The clutch, however, will take some time.
The price seems right so I'd go for it
^^x2 that sounds like a good deal for a truck and the price does sound right. Go for it.
oh yeah im paying for ir now
the clutch no prob the heater core i hate touching thoes
if you did it in 15min let me know how you did it
A Heater core on a '95? I thought you had to take the entire dash out. Not the same as on a pre-95, which is indeed a 15 minute job.
