flash550
- Sep 2, 2018
- Age
- 48
Hello all! I decided to forgo the mass introductory post since I do not own a Ranger and this is the only area of the forum I will frequent.
I am in the early stages of building a Glen-L “Dyno Jet” wooden jet boat. I secured a jet pump from a late 90’s Yamaha Wave Raider 700 and picked up a 2.3 out of a ‘93 Ranger to spin it. I am going to have the driveline complete prior to starting construction on the hull.
The 2.3 is complete less accessories, which I do not need anyway, and I am in the process of tearing it down to see what I’m working with. So far, so good. Some heavy surface rust but the valve train is spotless. Pulling the head today to get a look at the cylinders and pistons.
My first question for all you 2.3 experts is this: should I keep the EFI or slap a Holley 350 on it? I am leaning towards the carb simply because it would be cheaper, easier, and I can tune it without expensive software purchase. However, I have the complete wiring harnesses minus the ECU, so if anyone can make a case to keep the FI, I would love to hear it.
Thanks in advance, and I look forward to our discussion!
