flash550
- Sep 2, 2018
- Age
- 48
It is generally done with a heat exchanger, it's called raw water cooling. Sea water is pumped through the heat exchanger with an impeller pump, the engine cooling uses the engine water pump which is really a circulator and it circulates the engine coolant water through the the heat exchanger. all these types of marine accessories for engines have been around for a very long time and I think it would be less complicated than trying to use a radiator.
https://goo.gl/images/wCSXCc
A heat exchanger is a good idea since I could tap off the jet pump to move water through it.
