Dr76
- Aug 23, 2008
'93 2.3L is currently "clacking" when under load, but only after it warms up (driving a mile or so, here in FL). I can only reproduce this noise when in Neutral if I quickly snap the throttle (and again, only when warmed-up). Noise is (or seems to be) from under the valve cover, but it holds a steady vacuum of about 18 - 19" at idle. I currently have the valve cover off and see nothing obvious.
* Are there any type of "deflectors" available for oil control when operating w/o the valve cover? After reconnecting MAF and TB, I did start it for a second or two and probably lost a quart of oil in that time and made quite the mess!!!
Any ideas on the "clacking"???
Thanks!
Thanks!
