YungICY
- Jul 19, 2013
I think my engine jumped time and I'm trying to figure out the cam timing marks. They look different than those of the pictures I've been able to find via Google.
This picture shows the cam gear in relation to the crank at tdc. I have the small tooth like mark on the inside of the gear (top of cam gear) which appears to have a minuscule arrow pointing downward from that position. I don't have an arrow anywhere on the back timing belt cover, just those three teeth at the bottom. As best as I can tell the arrow on the gear lines up between the first and second teeth of back cover.
Is this in time, off a tooth or two, or off 180*?
This is an 85 ranger with the 2.3L.
Also the symptoms were, I got a bad misfire on I believe cyl no.4 (checked by pulling plug wires and 4 was the only one that didn't affect idle condition.) Replaced the: wires, plug on 4, cap and rotor. symptom didn't improve. I had to get to work so I tried to hobble it in, I got on the throttle a little and experienced a 1-2 second loss in power, a puff of white smoke (oil I believe) and back to the original misfire condition at which point i pulled over and called a buddy to tow me.
