87ranger2.0
K I'm sorry as far as finding a better carb 2.3 head, manifold n carb what other makes beside a ranger can I look at?
Is it doin a good job?..i seem to remember you were having some flooding issues some time back?..with maybe a fuel pressure issue?..I'm asking cuzi still haven't decided which way to go with the engine i'm building for my B2..either EFI or carbed w the 5200 and the BIG VALVE version of the 79 Pinto head i just got back from having large valves put in. Just so happened that a friend had the valves...and the cutter to mod them ..the block will be a "94" .040 over.
K I think I got it this time lol
that is the same intake on my truck and I modded the adapter plate to fit the weber onto my truck. I just removed the egr and built a block off plate.
are 13MM. And the 12pt hex ones can be re-used.
about boring the block..i would have to say I'm not sure..Some have said yes, some no. It may depend on the casting series of the block?...I had an "86" 2.0 block from a Ranger that i stripped..and the casting seemed similar to a Turbo coupe block w/o the drilled oil hole...since i already had a TC block i didn't keep it. I would ask the folks that race these 2.0L's
Racer Walsh, and maybe Esslinger.....they have web addresses..and are listed in the Tech library. If it could be done i imagine more would do it..especially for turbo use cuz there are a lot of Original Turbo forged piston/rods that are "standard"..with no available o'size stock pistons which were preferred ....I have a set..just no good "standard block"..
if your block has a cast nubbin on the passenger side in the middle about halfway back...don't toss it till u find out...The pic I include will show the oil drain boss w a tapped hole..
some good info..
http://www.merkurencyclopedia.com/
Best wishes....
Best wishes....
here also is a good sight for info....mostly turbo stuff but the engine basics are there...
These are the line I'm talking about in my above post
Well my block doesn't have that cast nubbin on the side.i started to pull my engine apart.i got the head off n it doesn't look like it had the d-shape ports but I didn't break it down yet.can you tell by just looking at it with the head off? What is up with all the vacuum lines going to the intake manifold?they look like shit.lol can n will the truck run k n pass an emission test w/o them?
ty guys.that sux about the vacuum lines.I'm glad I took alot of pic of where the lines go lol.well in the state of tn the emis test is check the comp for codes,the exh. n the gas cap. that what they did for my wifes 02 focus.ive only lived in tn for 3 yrs now n never had my ranger go throw emis here yet so idk.
I didn't notice the dash-pot on the carb for the idle speed on the carb. If it has a puter it should be on the passenger side fender-well i think. It may have a puter to check the AIR pump controlling valves...in any case I'm sure it'll benefit form a refresh of the bottom end and a valve job...maybe you should check your own codes when u get it rebuilt...
As you rebuild...keep an eye out for valve/piston issues if you add a 2.3 head (bigger valves) especially if you shave the head or use a higher lift cam (there can be valves interference issues especially if you break a belt while running) and if you push much more than 9.5/1 or so watch out for detonation with today's gas and no puter to help with spark/fuel issues with that motor..
I'm sure there are some bro's from TN on here can help you thru the emissions things....we'll be wishin you well from the left coast....
