1st Gen ranger 1st Gen Bronco II Guage Cluster Question...
87xlranger
April 2010 STOTM Winner
MTOTM Winner
Lakeview, CA
My Truck Has the 2.3L and I pulled the Guage Cluster out of the same year Bronco II with a 2.9L that has a Factory Tach. My Question is Does anybody Have Pin Out Information on the Bronco II Vs. The Ranger with No Tach So I can switch the Pins Around so everything will work ??
Light Green/red wire off the coil should be tach signal.
Look for that wire color behind the cluster. If it's not there then you'll need to run one. I would suspect that there is one already there, and would be a plug and play.
If you find out the pinouts let me know. Would save me from having to trace them all.
yea i'm still looking for pin outs, But my truck is at the bodyshop right now, the dash is almost completely out and it's getting repainted so I'll just have to figure it out I guess....
