RaptorRanger
Alright, my truck is having a fit. 1999 4x4 4.0L Ranger, check engine light is on and its throwing P0141, P0306, P0303, P0174, P0171 codes. 02 sensor short circuit, cylinder 3, and 6 misfire, lean bank 1, 2... I am thinking its an upper intake manifold leak.
I have replaced:
3 new O2 Sensors (2 upstream, 1 lower after the collector)
new spark plugs and wires
new fuel filter
The mechanic thought the O2 sensors would do the trick. Nope. Going to put in a new upper intake manifold tomorrow and see if that does the trick.
I also heard about a vacuum line near the fire wall on the backside of the motor that apparently is elbow or "T" shaped that is problematic.
Thoughts?
Thanks guys. (and gals)
I have replaced:
new fuel filter
Thoughts?
