If I was going ot upgrade my trackbar and mount, I would go with the trackbar that escort_gts has and a mount like his too.
I have a Rugged Ridge trackbar. It is for an xj with 6" lift. It worked fine on my other truck, but the 93 it has less lift and I had to shorten it by 1". Had to cut threads off the frame side to get it short enough cause it was bottoming out. It also has rubber bushings that need replaced. I would suggest getting the one that Rusty's has with the heim joints instead of the bushings.
Sent from my EVO using Tapatalk
