1997 XLT extended cab back glass
97ranger22bronco
Dallas, TX
The back glass on my '97 was smashed a long time ago and I'm looking to replace it; I can get it out with relative ease i think and a local junk yard has one I can get, however do i also need a gasket for it? Or is it held in by other means?
I think it depends on whether it's a supercab or not. I know it does in 88.
The supercab rear windows are bolted in with a thick layer of butyl tape.
Apparently regular cab up to 97 used a solid rubber gasket. If it's flexible it might can be reused...
Mine is a '97 supercab and that looks like a gasket?
its screwed and glued. i have one waiting to go in my truck that is that style.
So just butyl tape? Nice! Whole lot easier then messing with a gasket
well....its a bit gooey depending on temp. but for sure way easier. at least on my junk....
sometimes they wil have more
bolts/pins and may have to drill a hole or two. but once you get the trim off it is pretty simple.
