I just received my official Ford Motorcraft thermostat.
It does not have a little hole like the ones from autozone...so I guess I won't be putting the hole at the top.
ALso, I got an aftermarket gasket...amazon didn't seem to have an official ford motorcraft gasket...and I was hoping one came with the t-stat..but ordered this one with the t-stat just in case.
When I put the last one it,...I put it in the way the old one came out..without regard to looking up if the old one was in correct.....I usually do things that way..but in this case...since I KNEW the t-stat was not original, I should have looked it up.
This time, I am putting it with the tee-pee side toward the radiator and the spring side to the motor. (I'll find out shortly if the old one is correct).
I better get to work. It's dark already.
By the way, the part # is F8CZ-8575-AA, Motorcraft Ford, Made in Mexico.
