1996 3.0 4r44e with P0741 need advice!
St.rAnger96
ASE Certified Tech
Texas
Truck has 139k. Runs and drives ok. A bit slow. A bit weak. No big deal.
It had a flashing O/D light soon after I got it. I did a fluid flush, filter replacement, tightened the valve body, replaced two solenoids. It went away for several hundred miles.
Now the shudder is back and I get an intermittent flashing O/D again. P0741 stored code.
Can someone with a better understanding of these Ford transmissions help walk me through some troubleshooting? I want to exhaust some possibilities before going through the hassle of pulling the transmission in my driveway... And then renting a truck to take it to a shop.
you probably only needed to swap out the tq converter, with the e4od that thing liked a converter every 100 k or so.
hard to say though with these units.
