1993 Splash build
Your still independant, I found a pair from a TRS member I'm getting, should be good for my setup...
SVT
:icon_thumby: Can't wait to see what you cook up with this build.
It's getting close to being a build thread started, I just made a deal to get the engine and trans for the project. Coincidentally, its the same motor and trans that was originally with the cab. Only thing I need now is a rear axle, hood, grille, header panel and lights...
SVT
Finished cutting all of the pieces out of cardboard that I need for my canned ham bracket today. I need to use the plasma cutter at work to cut out the pieces.
I'm about 3/4 of the way done with my canned ham bracket. Will post photo's when I'm done with it.
I tried to make one too, and it didn't turn out well. So I need to make another one
Sent from my HTC VLE_U using Tapatalk 2
Lol yea, it's taking a lot of measuring and :icon_welder: I'm copying the OE aluminum bracket almost to a 'T'. The only thing that's different is the bolt pattern for the pump to bolt to.
What are you going yo do with the old pump and bracket?
Postin' from teh Galaxy
No idea. I have a bracket off of a 97 and I'm sure the bracket off of my '93 will be the heavier duty one. Probably sell them. Why, you interested?
I know Gen II Rangers had the HD full circle bracket, is your 93 bracket that way? My buddy may be interested in it for a Saginaw swap on his B2.
-PlumCrazy
-PlumCrazy
I'll have to check tonight when I get home. I didn't like the thought of grinding the hell out of that aluminum bracket. I don't want it to fail on me. That's why I'm making a new one out of steel.
I agree. Unless you have the TBird style resi the 4.0 brackets wont work.
-PlumCrazy
Yea, TnT's truck is running a modified aluminum 4.0 Bracket with a canned ham style reservoir and it's working but he said it does look "hack"
Yeah. The 4.0 that I bought came complete, except for the PS pump and bracket.
You can have the one off of the '97. $20 it's yours.
I finished my saginaw bracket tonight. Worked beautifully as far as it bolting on lol. I'll get the pump on tomorrow and shim it to it's proper place. I'll be re-using the OE ford pulley that came with the pump coupled with a proper length Goodyear Gartorback serpentine belt so I don't have to resize the hole in the ranger pulley. I found a website with part numbers and lengths so all I have to do is measure for the proper belt and be set.
Here's the website: http://www.goodyearep.com/productsdetail.aspx?id=3128
