1993 Splash build
Yes, very pretty!
JKS apparently doesn't make these u-bolt plates anymore. No idea why. They were originally made for a cherokee but work perfectly on a ranger for 3" or 3.25" axle tubes.
Nothing really to update. Got a pair of spindles for the axle.
I've been working on rewiring my house and getting my garage ready for concrete. Seeing as my breaker box almost burned the house down, I'd say that takes precedence over the truck build.
Yeah, I agree. Glad it didn't catch fire. As always, you know us, PICS of the build! Even if it is the garage and wiring...lol
SVT
That is a good call lol
I DO have good news though. The truck's getting a frame off restoration. I bought a parts truck. A pristine 97 extended cab 2wd ranger. The cab has NO dents, and NO rust. Frame's also in perfect shape. Looks like I'm SASing this one instead. Plans are to completely rebuild the drivetrain. The 4.0L will be a factory rebuild with a comp 210 cam, chromoly pushrods from Smith bros (already have them) and hardened rockers from Delta cams (already have them). Tranny will be rebuilt to factory specs other than a shift kit (4R55E from a 97 explorer I got for free 2 days ago). T-case is already rebuilt, sandblasted, and ready to go (1354M). The truck will have a flat bed with an RCI fuel cell.
410***
Just bustin' your balls.lol
Sent from my DROID RAZR using Tapatalk 2
So when is all this going to happen?
Sent from my HTC ONE using Tapatalk!
It's been happening. The cab's off the frame. Axle's 3/4 of the way complete. Motor and tranny still need rebuilt. I'll wheel my white one in the mean time. This will NOT be a fast build.
I knew you had the axles, didn't know you had a donor ranger.
Yea it's nice lol. I can do all the custom fab work I need w/out the body on like suspension, crossmembers, modifying the engine crossmember, etc. extremely easy.
Might as well box parts of the frame while your at it
Part of? ALL of it will be plated. With drain holes on the bottom and hand holes in the center (approx. 3.5" holes to feed wires/fuel lines through)
Pics and new build thread, or is it going be built using this thread? You will like the 95+ firewall/dash/electrical system, far superior to the 93-94's...
SVT
Upcoming TRS Events
