2.3L ('83-'97) 1993 2.3L Giving trouble codes 223, 224, & 998
HighMileage93
Bridgeport, IL 62417
Just want to get some feedback from those way more experienced at this stuff than me. I Started with the KOEO test and it immediately flashed 111, then reported codes 223 & 224. Started the KOER test and it flashed 998 & 224 but never flashed the engine ID code (2) to tell me when to turn the wheel and hit the brake pedal. Am I doing something wrong here?
223 - (M) Dual Plug (DPI), SPOUT or IDM circuit fault – Ignition Systems
224 - (M) Failure in ignition coil primary circuit – Ignition Systems
998 - (R) Did not pass Key On Engine Off test yet (Get 111 in KOEO first)
(referenced from OBD-1 Diagnostic Trouble Code - Ford 3-digit Codes from the Tech pages on the main site)
