1992 ranger 4x4 4.0 supercab 5 speed swap
Trickflow43
Findlay Ohio
2in suspension
I've been researching this swap as my a4ld lost park and 2nd gear. I see I need a M5OD-R1 trans the clutch/brake pedal from a 90-92 the master, lines, slave, flywheel, and clutch. Wiring isn't a big deal as I can figure that out for my lights. My area of question is I know my 1350e case will bolt up but can I reuse my drive shafts, do I need a manual ecm because I see that posted both ways? Also let me know if I missed anything. Thanks!!
The clutch/brake pedal bracket.
The pcm will work but I think it idles high and gives a cell because it looks for solenoid that aren't there.
Do you know if my stock automatic driveshaft can be reused?
I don't know. I think there is something in the tech section that compares trans length.
