I just acquired an incredibly clean 92 2.3 4x4 5 speed with 78k on it. Everything seems to run well and work as expected, but I've noticed an odd driveline noise and I'm not sure if it's anything I should be concerned about. When decelerating and using engine breaking, there seems to be a bit of a grinding noise coming from somewhere in the driveline. It happens regardless of the gear. If I'm in neutral and release the clutch pedal while coasting, there's no noise. If I push the clutch in, no noise. If I press and hold the gas pedal just a touch, the noise goes away, and if I'm just coasting in gear without any engine breaking, there's no noise.
Should this noise be concerning? Any ideas where I should start looking? Other than the noise, it seems to drive and shift perfectly. I do know that about 5000 miles ago the truck had a new clutch installed and the flywheel was resurfaced, along with a decent amount of other work.
Thanks in advance!
Thanks in advance!
