1991 tdi ranger swap 4x4
Artemb
Forum Member
Stanwood
CT-USA
Vehicle
Drive
Starting on my 1991 ranger tdi build want to keep track of it and progress. I have 91 ranger 4x4 extended cab that I want to tdi swap and also do a full Jetta 2006 interior from the donor car which would include seats center console and Sasha s wheel as steering column
Pictures haha. Looking forward to seeing your build take place.
Currently have the hood off and stripped the interior waiting to get my buddy’s cherry picker to pull the old 4.0 other then that goal is to try and start getting the Jetta interior mocked up
Working on getting stock 4.0 engine and trans out
Liking the look without a bumper I’m considering doing a skid plate and no bumper
I 'd suggest some form of bumper, even if it's just like a piece of 1.5 tubing or something. Something to make a full width skid plate attach to.
Yeah I was thinking about getting one of those full steel off-road bumpers
So I decided to cut the frame that connects the front end of the truck so I can remove it and have full access to the engine this way it will be easier to run wiring and mount the tdi engine in I made brackets before hand and bolted them in then took them off cut the truck and put them back on once the build is complete I will install the brackets and then weld the remaning cut for max strength
been working on the front end of the truck getting the suspension components and brakes and stuff all off I’m thinking about doing disc brake conversion in the rear any suggestions? Is it very difficult? Is it worth it?
Someone did the math here awhile back and showed all of the Ranger brakes to be similar in stopping ability. (Excepting the 9" drums)
I went disc because I hate drum brake hardware, and I wanted the 31 spline Explorer axle. 95+ was more common in the salvage yard already.
Yeah I’m thinking about doing discs for the same reason you did, their much easier to work with but I tore deep into the truck today(because I’m painting the frame) and I checked out the drums and it looks like someone just put on new hardware so I think I’m going to run them until they wear out and then switch to discs
Also I’ve been trying to get the knuckle off of the front end since I’m doing new ball joints and full front end rebuild Im having a really tuff time trying to get that lower castle nut off above the lower ball joints their is also a cotter pin I haven’t been able to get on that goes through that nut as well as theirs barely any space to even fit a wrench
Any recommendations? It’s a 91 4x4
Pull the axle shaft first?
Frame looking good
