Wow! That's quite the list of activities! Fortunately, my list is shorter.... Even before I was able to drive it I had to get keys made, since the owner had lost the set. The Ranger is old enough that they don't have records of how to key the ingnition, so had to have that replaced. The locksmith was able to re-key the doors, which saved me a little.
When I got the truck driving it had a terrible noise in the front end, driver side... barely got it home.
1. Checked bearings - they were shot.
2. Replaced bearings in front (noise went away).
3. Noticed that every time I would get gas it would spill out on the road - suspected that the fill hose was broken.
4. Confirmed bad hose. Bought new hose (cheap online version).
5. Installed hose. It was so soft that it collapsed, so I had to cannibalize the old one to make a new one that would work. Oh yeah - you have to take off the truck bed to get to all of it, so several times doing that before it was functional.
6. Noticed that if you sit in the passenger seat and lean back, it will automatically recline. Discovered that when I had to pick up my 90-year-old dad from the hospital. He was not happy with the sudden transition. Still haven't fixed that (just tell people they have to sit up straight if they are going to ride with me!)
7. Couldn't get it into 4-wheel drive (suspected the auto-hubs were not engaging)
8. Got manual hubs and installed them.
9. 4-wheel drive still not engaging, but when I would lock in the hubs it would start this clicking noise that would increase with speed (seemed to come from the driver side more than the passenger side).
10. Thought that the manual hubs were not locking in, so tore the front apart (again) to evaluate - seemed to be engaging as designed.
11. Read a lot online about shift motor having problems with a bushing, so decided to tear that out and evaluate.
12. Was going to drive it into my wife's garage, but the incline and snow was too much (and I didn't have 4-wheel drive), so after getting stuck and having to use a chain and tow strap with come-along hooked to the tree in front of the house just to get it out, I decided to do the work in the carport (which has a permanent leak from the house heating unit), so ended up lying in water while I tried to repair the shift motor!
13. Couldn't get the red wire harness retaining circle out of the socket, so I couldn't get it away from under the truck; ended up working on it while lying in the water in the cramped quarters (I should have at least jacked up the truck so I had more room...). By the way, if anyone has a simple way to remove that red plastic retaining ring in the socket / wire harness I would really appreciate the help. I will need to do that when the new shift motor comes.
14. Bushing WAS bad, so replaced it and put the motor back together.
15. Reinstalled the shift motor onto the transfer case, making sure everything was lined up correctly.
16. Started the truck up, locked in the hubs, put it in 4-wheel drive, and gave it a test run.
17. No change - still a clicking noise that increases with acceleration.
18. Posted my dilemma on The Ranger Station Forum.
(don't you just love these old trucks?)!!!
