1990 bronco II acceleration problem.
Featured Build Threads
mandrake001x
10+ Year Member
I have a 1990 bronco II, that is mis-behaving.... the problem is that... it seemed to be running fine til I put a can of 'sea-foam' into the fuel tank to clean things out (fuel line and injectors). Now it will run fine for awhile, but then it starts sputtering, bucking and dogging when you try to accelerate in any gear, however the engine revs fine when in neutral or if the clutch is depressed and seems to idle fine... sometimes if you turn the key off and let it sit for a few it will run fine for a few mins but starts doing it again shortly.... I have replaced the fuel filter, and double checked that the new one is clear. I'm wondering if the fuel tank or fuel pump may be sucking up sludge that was loosened by the sea-foam ???... As I said, it runs fine when 'cold'... any suggestions would be gratefully appreciated. Its a 'work in progress' and not my primary transport. I have a 2001 gmc savanna van as primary, but enjoy using the bronco around town and 4 wheeling.
Give us more info. When it starts to bog check the fuel pressure and spark. Is the pressure in spec? Is the spark a strong one?
have you gone through a tank of gas yet. check you spark plugs, all that sea foam isnt good all at once. if i were you i would put 91 in it and run out. also when you fill up with fresh gas no sea foam replace you plugs. im betting you fowled them.
My experience with the cleaners like this is while it is in the tank the engine runs rougher. If you haven't gotten thru the tank yet, I wouldn't necessarily worry unless is shows problems with the next tank of fuel
Event Coverage
Featured Ranger Based Vehicle
