matt12305
As the title states..fuel gauge is not working. It's a 1988 XLT 2.9l. it has dual fuel tanks. Last year I replaced the front tank with the bigger 17gal(I couldn't find a 14.5gal), I also replaced the sending unit and the high pressure pump. I put around 4 gallons in the gas tank and my fuel gauge has not moved at all. I suspect it could be damaged wiring. What's the best way to check the wiring for it? Just follow the wire all the way down or is there a way to use a multimeter to check?
Please advise
On a side note, I am one part away..wait no 2 parts away to getting this thing running smoothly. Needs new motor mounts, and a new map sensor (got code 22 from obd1) after that, some new tires and maybe coolant flush and it'll be good to go.
Please advise
