1988 ford ranger question...
lakers1125
Could i take the back seats out of it and but like 2 subs in those slots? Would that work?
Anything can be done with enough time and money
Sent from the road while ignoring traffic
Like Kryptonite said, anything can be done with enough time and money.
The space that those seats fold into is not very deep, and might not give you good acoustics. your sub will need x amount of cubic inches of space to properly reverberate (thump). depending on what you are putting in, it may not have that exact amount. plus space that is behind those seats is open all the way to the door pillars and to the back cab wall, which will eat up any good acoustics. And if you have rusted out cab corners, your subs will get wet. If you have a decent body, you might be able to buiild a box that sticks out of the seat space or you might be better off building a sub box and putting it behind the front seat on the floor.
Hope this helps
AJ
Yeah, I was concerned about the amount of space that was there. I will probably just build a box to go back there. Thanks guys!
I don't know how loud you are wanting, but you might check out how some 8 inch Kicker L7s fit in there. They only need a sealed box volume of 0.33 to 0.75 cubic feet, and have a mounting depth of 4 3/4 inches. You could make a box out of fiberglass and MDF, using the fiberglass to kind of line the opening where the jump seats went to maximize the volume of the box. I had a single 8 inch L7 in my wrangler I used to have, and that thing by itself was plenty.
