1988 4x4 ranger first pick-up project
**** me the hole is bigger than I thought I would be, not sure if I should make a plate weld it or have a new mount rad side is top shape but the frame side oof not sure.
Also what is the box with 2 lines for? Looks like it goes to the throttle body. Is it a fuel prep of somesort or reservoir ?
That box is something I never figured out or knew how to hook it up
I was cruising the most congested bit of highway in TN one day near downtown Nashville and heard a very loud CLINK! and noticed the cab was sitting a bit lower than before
When I got home and looked in that area you are now, found a bedframe type angle maybe 1 1/2 X 2" by 2 ft or so and pulled up on the upper frame and slipped the angle into that corner, where it rode un bolted till the day I sold it
Yeah it's the weirdest, only 2 tiny hoes going to it and 2 caps on top. Kinda want to take it out and open it..
So you rode on an unbolted cab to frame ?
God have Mercy that is a veryyyyy wore out cab mount only had time to take 3 out of 6 mounts but I'm gonna assume the rest also looks like this. So now I'm considering making 6 hole new brakets from slightly thicker steel...
That's what the loud Clink! was, the bottom bell washer popping off into the freeway. After I propped it up a bit with that bed iron angle or whatever it was I never worried about it after that it rode solid again :)
If your frame is in any way better than the one I had you should never have the considerations I had with the rusted mess I had in mine, at least I had a couple months head start of chipping and painting to start, and a new factory built engine to keep it rolling on down the road, all totally free :)
Well the Frame is top shape just places where there are moving parts it's pretty much dead, bushings/ rubber also almost all shot, to be replaced. If I had the place to take it apart I would do it for sure.
A large washer welded in works.
The box is a charcoal canister for emissions.
I'm not sure what you'll need to worry with on bushings, likely the cab but then that won't get top billing.
My old twin I-beam had rubber bushings, if yours is I-Beam it probably has them too. Not a massive job but could be done well in a day. I even dropped the coil springs while I was in mine and put some home made rubber pads for them to seat into.
If you are looking to do yours really well try and catch a local antique cars show around town and maybe you'd find someone there just itching to tell and show you all about how they did theirs
pretty hard to find that big of a washer lol or at least that aren't like 50$ a piece , I have some scrap plates big enough at work that should work with the help of a lathe or hole saw. thanks for the answer for the charcoal canister btw.
thinking of it they should last for a while still, especially since I can't really ride it yet :cry: and that I have a few more pressing mechanical issues like having a hard time starting it when I need to move it. most likely just because the starter(new)/flywheel(old) are not happy being together and that the tank is nearly empty.
oh and the driver side door is being a bitch to close, gonna figure out how to adjust the latch tomorrow and do that on friday or on my lunch break
Is the door sagging? It could be the hinge bushings on the door.
Not too hard to fix but can be a bit tricky
Yeah it's sagging a little, it wasn't sagging a few days ago tho 🤔
Will it shift at the top hinge if you pick up on the door?
Yeah it shift at the top hinge I'm guessing I could just get newer pins and that would somewhat fix the problem..
But for now that'll be the last of my problem as I got a new one, more like a problem that got worst. Got a half day at work and got the beautiful idea to go and put like 20$ of gas in it started almost right up to go to the gas station but after getting gas starter did it's thing, no start tried again no start. It sounds like it spins the ring gear but not the engine... So had to call my boss to send someone to pull start me.. good thing I already have a new flywheel, clutch, etc. Ready to get installed. Kinda mad at myself for that event but oh well shit happens 😮‍💨
Get you a tool box with some tools and a spare starter in it ;) I got mine I think in 2003ish for 65 bux when I was driving the 87/88 one. It still rides today in the 93 :)
Get a spare at the wrecking yard, tear it down and check it out. Use jumper cables to bench test it, sometimes just a bit of sandpaper can get one spinning
only thing is the starter doesn't seem to be the problem, it's a brand new one (installed before I purchased it) my guess it that the ring gear either is dead or that somehow detached from the flywheel.
for the tool box and having spare parts that's a pretty good idea, not have a lot of space to spare behind the seats as of now tho the plastic tank, fuel tank skid plate, wheel covers and some other parts😅
