- Sep 22, 2007
- Michigan
- 2.9 V6
- My credo
- A legend to the old man, a hero to the child...
Have you pulled codes?I have not. Reckon that's next.
I wouldn't till you pulled the codes. On these older trucks, a lot of them did not have a check engine light, only a emissions light. You are correct, you need a testlight and a jumper and you should be able to pull the codes if you can find the plugs under the hood. A old type multi-meter with the needle will work also to read the pulses.I have not. Reckon that's next.
My 86 never had a check engine light, it never had one from the factory. It may be your 87 doesn't either. You can still get the codes by using the plug under the hood, passenger side, buried close to the firewall.I've tried to pull codes. Even though I have a spot on the dash that says "Check Engine" it doesn't illuminate. My multimeter is digital so I need to buy a test light.
Have you replaced the MAP?
=only thing fersure is uncertainWell, that had no effect. Also, I am getting spark because the timing light blinks when hooked up.
Assuming you mean MAP? lol either way glad you got itI replaced the MAF and it works now.
Little black box on the firewall, passenger side? Lol.Funny, I was certain it was MAF, but then again, I am often wrong.
