keebler
- May 7, 2010
- 1986 and 1987
Im trying to remove a front drive shaft from a 1986 ford ranger with a 1350 borg warner transfer case. It has the splined shaft to the transfer case. I bought the truck with out a transmission or transfer case and my usual fords had the easy four bolts to remove before. Someone please help me so I can finish the project. Just about all I have to do to finish. And if I could get those for small bolts out of the driveshaft never the front differential, i could just leave the shaft in the transfer case and not worry about removing it. When I bought the truck, the front shaft was still attached to the differential and any wrench or socket I tried keeps slipping. Any help would be appreciated. keebler
