I recently bought an 84 Ranger for cheap. 140k miles, body is perfect but engine overheats (on a 100° day it will drive for about 20 minutes on level ground before approaching the top end of the normal range on the temp gauge) and runs a little rough.
I plan on doing the duraspark conversion, but the overheating bit has me thinking I need to tackle bigger issues first.
The radiator feels hot as well as the upper coolant hose. I put in a new fan clutch… but the fan clutch doesn’t seem to be engaging when it gets hot which leads me to believe the hot water is not circulating through the radiator.
Should I be preparing for a head gasket replacement? There is no coolant in the oil, but there was a little bit of oil residue under the radiator cap.
