other way around. Like, I'm buying a 1987 long bed and I want to swap in a different 1st gen short bed. Looking at it it might be a straight swap, but I don't know if the wheel well is in a different place, as well as different mounts
wheel base is different iirc; reg cab short bed = 108" while reg cab long bed = 114"
Inorder to make it look correct you'd have to cut 6"s out of the frame on the either side of the axle then shorten everything else up like driveshaft, fuel & brake lines, & wiring the necessary amount.
Definitely not a straight swap to have it look right. Cutting and welding will be required. You'd be better off buying a short bed if that's what you want. Or if that's not an option, maybe swap the cab over to a short bed frame.
For
