85_Ranger4x4
Wallers in rivers
TRS Event Staff
💻 TRS Socials
OTOTM Winner
- Aug 7, 2007
- Frankfort
- State - Country
- IA- USA
Just my $.02, but I'd fix the pans right, since they are a major structural component of the body, fix up what ever other body problems it has, and be glad it doesent have T-Tops if you want to run it hard, especially the Fisher tops they had in 78-81. Now, with the Pontiac 400, you can get a 467ci stroker kit for it, aluminum heads and intake, and you have a stronger block than a SBC. I mean, if you have the W72 400 in it, stock you have 220hp@4000rpm and 320lb/ft@2800rpm. The L78 400 only had 180hp. BUT, if you have the L80 Olds 403, have fun making power and and keeping it together. The 403 has "windowed" main webs and siamesed cylinders, and they tend to blow head gaskets when you raise the compression. Oh, and swap the 10 Bolt out for a 12 bolt Posi.
That green is kinda hard to read...
gonna start saving alot harder...
