1350E to 1350M parts interchangability
88_Eddie
Solid Axle Swap
Raleigh, NC
If any of you have seen my build thread (link in my sig), I just swapped a 1350E for a 1350M. I was gonna just scrap it yesterday, but then I thought that some of the parts may fit my manual case.
After seeing another thread where someone cracked the outside of their t-case, I thought I should hang on to whatever could be used if I break something in my manual case.
I know I can't use the front of the case, but what about the chain, planetary gears, etc.?
thanks in advance
You can use the front plate on the case, it will swap between any 1350, I know some insides swap over too but not sure which ones. I had a 1350 dummy case in my choptop when I bought it, and I had a 1350 manual case that had a cracked front plate (the piece that bolts to the trans). The one off the dummy case fit the manual case perfectly, I just had to pull the clip and swap the planetary over. Wasn't hard at all.
Most of the parts will swap into the 13-50m:
The front plate
The planet gear set/ input shaft
Output shafts (both front and rear)
Chain
Both shift forks and gears
Oil pump
Wont fit:
Rear case half (will work with some easy mods)
Front case half (will work with some major mods)
Shift rod
