I didnt know if all the stuff from the bII would fit becouse my truck is a ex cab and i was told i had to change the drive shafts to do it and i was going from auto trany to a manual tranny and the wheel base looks like alot shorter on the bII
The front driveshaft should be the same on both trucks, use whichever one looks best.
The rear driveshafts will not swap though, your Supercab's rear shaft must remain with the vehicle.
A4LD and FM146 (what the BII should have) are the same length transmission.
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
