PetesPonies
Pictures are worth 1000 words huh? I bet to people on this forum, this picture says a lot
Once I build the heads, it will be going in . . not long now.
Is the fuel pump upside down?
That water pump aint gonna fit!
At least not in a Ranger....![]()
Pics of the truck?I don' have a stock front . . I have an early Bronco grille![]()
Pics of the truck?
And what's the advantage of an using an inverted fuel pump? Just wondering since I've never seen one.
Pics of the truck?
2 objects cant occupy the same space.![]()
Who says they have to?
However I have yet to test the effectiveness of the pusher fan... I figured what the heck and tried it, worst case I have to get a different fan blade and a different top hose.
On a 60 degree day idling, the mech temp needle just flinched back and forth at 190 as the stat open and closed. When I get an exhaust on it and the temp gets higher we can do some real testing though, so I still classify this as "experimental"
But the long pump fit fine with a Ex rad mounted in the stock location, I have about 5/8" between the two.
