If you are strictly going to be on the road a 10" wheel will be best on a 12.50 wide tire. If you are going to do both, then a 8" wheel will be your best bet with a 12.50 wide tire.Rim width depends on how wide your tire is going to be. With a 12.5 width tire, a 10 inch rim works well. Anything narrower and an 8 inch rim will work fine.
one question,
why the Show Off forum?
I dissagree, 12.50s should be on 8" wide wheels, maybe 13.50s too, anything after that go with 10" wheels, 10.50s I'd rather have on 7" wheels, many peaople run 12.50s on 7" rims as well. I like going with the narrowest rim possible, at least in my aplication, it holds a better bead when aired down.Rim width depends on how wide your tire is going to be. With a 12.5 width tire, a 10 inch rim works well. Anything narrower and an 8 inch rim will work fine.
