92exploder4x4
- Aug 29, 2010
- Automatic
NM
mine used to get about 20 then it dropped to 16...still working on it, getting close to setting fire to it. Don't worry, I have liability only so no fraud involved. Just a sweet explosion.
thats the way mine is.. got 20 in town at first, now its running rich and yada yada and now i get 16 in town. still aint to to bad i guess but i loved LOVED loved that 20
mine runs great.. just rich. my pressure reg is bad.
while on this subject, has anyone used the adjustable pressure reg from summit?
well crap i can't find the link now
also, i have one of these, it does help
http://www.summitracing.com/parts/TAM-KI-75/
idk if that's the actual size or not but you get the pic, its the tornado.
biggest things ppl dont check.
brakes rubbing?
tranny slipping?
check your diffs for fluid
check your wheel bearings for worn out parts
your cat may be clogged and the majority of your exhaust is being pushed through the leak.
truck could be stuck in 4wd
injectors could be clogged
you could have a fuel leak
your gas cap may be allowing air in
and the biggest one that happens without you knowing. somebody could be stealing your gas and your truck could be working fine. making your readings come to 10 mpg.
grab a locking gas cap and you may be good!
So it runs rough? A well tuned engine will move around under acceleration with bad motor mounts, but should still perfectly still at idleCould bad motor mounts cause a decrease in mileage? I know mine are bad/going bad, m motor shakes like a mofo - even under acceleration.
