1 ton, caged ranger
Lol ya, the wire wheel was spraying 20 years of road grime all over me. You should have seen what i swept up after i was done
should change out the wheel bearings while you have the seals out.
I was actually gunna ask about that, so i def will. I tried to find a lsd rebuild kit online and couldnt. Any leads on that?
youve got a welder dont ya :D
Lol ya, kinda done with that haha. My tires are waisted.
1 ton, caged ranger
New brake drums, thursday I will be ordering a LSD rebuild, wheel bearings and an easy out....
So I decided to build a truss for the 8.8. I started by ripping a 2x4x1/4 in half
1 ton, caged ranger
Then pie cut it and bent it
1 ton, caged ranger
Then I trimmed down the ends to make it fit.
1 ton, caged ranger
I am going to trim the ends a bit more to get it to fit tight. Also I am going to plate all of it in, in between the truss and the axle if that makes sense. It will make a good base to build a traction bar and will be good if I decide to jump it :thefinger:
Also I welded another pass on the axle tubes.
Question, when I weld the truss to the center section I need to preheat it correct?
yes theoretically you should, but did you pre-heat the housing before you welded in your axle tubes? same difference. Some guys will tell you to pre-heat, others will say go ahead and pull trigger.
Also, make sure you peen your stop/start points.
I didn't preheat when I welded the axle tubes, but after the first weld at level 6 it was pretty hot lol. I will when I weld the truss, to be honest I'm not too worried about it
pre-heating is really only necessary if you do not have a welder that gets "hot" enough....
with a 220v welder you should be able too....
l8r, John
Sold my switch panel and got a paycheck, more updates tomorrow...
