couldent you also just cut the harness and get a new one with a two bulb set up and splice the turn signal into a bulb that has two wires in it (for example one from a 2000+ ranger)
So what you're saying is the Gen. 3 93-97, will fit 98-08s? - Aside from the 93-99s being a 3-bulb and 00+ being 2 bulb of course!
I just bought some aftermarket tails for a 01-05 for my 96 to try and make them fit, Although I might be getting a 99 flare side bed now, so I was worried that they wouldn't fit
Added: So i thought, I am in the process of doing a 2 to 3 light conversion without success, afraid of the missing brake signal in the OEM wiring causing havoc with other functions; checking it out.
For
