Other than the engine were is the tick comeing from ? Is it low on oil ? what type of gas are you running ? need more than its ticking to help out here.
If it is an 04 your should still have some warrenty left ?
Unfortunately my computer is soundless, so it is hard for me to figure it out.
Could you give an idea of were the ticking is coming from. And is it a loud tick ?
I would guess the noise is coming from the top end. If this is the case, you may be able to rebuild the heads/valvetrain and be done with it.
Have you run a compression check on all cylinders? It looks like it is misfiring. There is a good possibility a compression check will tell you what cylinder has the problem.
If you aren't really familiar with engines it would be well worth the expense of paying a good shop to diagnose the problem and go from there. Depending on where you are and what shop, expect to pay about $80 to $120 for an hour of diagnostics.
I called a guy on a rolled 04 with a 2.3. So I might pick up that one for a back up if the damage is too much in mine. Well see on sunday when the guy calls me back on a price.
For
