04 2.3 rebuild
whtout
I have a serious, knock/tick in mine. How do I solve this?
Thanks
Other than the engine were is the tick comeing from ? Is it low on oil ? what type of gas are you running ? need more than its ticking to help out here.
If it is an 04 your should still have some warrenty left ?
truck was bought at auction. Would a video of it running help you figure out where I should start.
Thanks
Unfortunately my computer is soundless, so it is hard for me to figure it out.
Could you give an idea of were the ticking is coming from. And is it a loud tick ?
I would guess the noise is coming from the top end. If this is the case, you may be able to rebuild the heads/valvetrain and be done with it.
Have you run a compression check on all cylinders? It looks like it is misfiring. There is a good possibility a compression check will tell you what cylinder has the problem.
If you aren't really familiar with engines it would be well worth the expense of paying a good shop to diagnose the problem and go from there. Depending on where you are and what shop, expect to pay about $80 to $120 for an hour of diagnostics.
I'll try and take it to a shop...we'll see whats up. Is there any info I can get on this 2.3?
Later
what do you think it is?
later
I've heard that sound from an Eclipse before- it was a thrown connecting rod.
I called a guy on a rolled 04 with a 2.3. So I might pick up that one for a back up if the damage is too much in mine. Well see on sunday when the guy calls me back on a price.
Later
From the sound of it looks like some valve train noise. A top overhaul if all the compressions tests are okay.
What was the result of the shop diagnostics? Get the engine from the rolled-over truck?
